I have 1 drum brake that stops hotter than the other 3. I replaced all seals because of grease leakage. Hot brake was greaseier. I cleaned better than others. Do I need to clean other 3 better? Do I n...
As was said grease will soak into the pad and cleaning them with solvent will not get it all out When you apply the brakes the shoes get hot releasing the soaked in grease. This also could cause the brakes to grab making more heat. Hope you get it fixed and let us know if you get the issue resolved.
