I have 1 drum brake that stops hotter than the other 3. I replaced all seals because of grease leakage. Hot brake was greaseier. I cleaned better than others. Do I need to clean other 3 better? Do I n...
Took a trip around lower Michigan. Took about 50 miles to feel brakes working. Did a temperature check, about 10 degrees variable. Stopped with less side pull.got back to Grand rapids son's house. Did a brake adjustment, ready to head back home to Florida. Except for another broken spring hanger, found broken one on way up got it fixed in Tennessee. Time to find a welder.
