anchorExplorerJul 22, 2014Hot Water --Help36' Keystone Challenger 5th Wheel. Full timers with 31' Class C also. 5th Wheel--Hot water does not come out of faucet. I emptied tank (turned off heat), changed house filter, filled and released th...Show More
rv2goExplorer IIJul 22, 2014Some units have check valve in the hot water line leaving the water heater. The little plastic plunger can break, cutting off the hot water flow.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
Related ContentNo flow from hot water tank Nautilus P1 systemHelp w/ hot water heaterNeed help, hot water tank fail.Hot water heater question .....Help: leaking hot water heater
