wa8yxm
Jun 28, 2015Explorer III
There are basically 5 things that can make the LP FAULT light light.
1: LP issues (I assume you have LP and the tank valves are open but hey.. Got to ask). Also regulator issues (How does the stove work?)
2: Clogged gas jet.. There is an insect that likes to nest in gas jets.. They can clog from other things too
3: Flame sensor issues. Yes they can go bad
4 Ignition issues.. Often I find spark gaps too wide and considering I only work on my own and my parents... 75$ of the time I've found spark gaps too wide this is not a good "It's ok" rate. The water heater by the way was the other 25% The only on set right
5 Control board issues.. My OEM took at least 3 tries before it worked when cold
The Replacement COntrol board is much better.
