cameo_37's avatar
cameo_37
hot water heater lights but won't stay lit
I have a 1999 cameo 5th wheel. It has a Suburban gas water heater. It will light, butgoes out in a few seconds. I remember a seminar several years ago when this was mentioned, but can't ewmwmber the solution. We used a compresser to blow out all the rust & debris. Does anybody have an answer. Thanks.
  • Bad thermocouple? Should be 'in' the flame. Is used to sense that the burner is actually lit and if it is not lit (or the thermocouple is bad) then it will shut off the gas supply. You could also try scrubbing the thermocouple with a wire brush or sos pad to knock off the soot buildup that could be on the end.
    Poor air supply? Run it with the door open, does this help any?
