lschultz's avatar
lschultz
Hot Water Heater Problem
We have a Girard Tankless hot water heater that unfortunately, didn't work this week while camping in Cape Hatteras. Thus, no hot water the whole week. We can't find anything wrong and did all the troubleshooting tricks we could think of. We didn't hear it kick on/ignite like it usually does when working. Has anyone had any problems with this heater system that might offer some tips to try before we end up ripping the whole thing out and throwing it in the garbage? We have had nothing but problems with it the whole time we have had our coach. We have a 2013 Coachmen Cross Country RV. Any help will be greatly appreciated and thanks in advance.
  • For the GSWH-1 Model
    LED light on user panel 'fault codes'
    • Steady On - Internal Control Fault
    • 1 Flash - Air Fault
    • 2 Flashes - Flame Detection Error
    • 3 Flashes – Lockout
    • 4 Intentionally ‘NA’ – Reserved for Future Diagnostics
    • 5 Flashes - Low voltage
    The GSWH-2 Model 'error code' will be on display panel
    E0 thru E9 plus En or Fd codes
    GSWH-2 Error Codes......pg 18/19
  • Check the manual reset high limit thermostat inside the unit. I think the first units have had this problem of the limit switch opening. The new ones have auto reset ones in them, at least mine does.
  • Power? Did you check the breaker for it? Did you verify it has 120VAC? If ots a gas only model, did you check fuses to prove it has 12VDC to it?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
