GC6a-10E..
Swapped both the t-stat and eco sensors.
Removing ECO wire did not turn on any lights, and I could still hear the high pitched sound of the heater active. Removing t-stat wire did not turn on any lights, but did stop the high pitched sound.
No light comes on to indicate demand either?
Old-Biscuit wrote:
Atwood 6 gal...............?????
WHICH MODEL of Atwood 6 gal?
GC6a-10E uses on set of t-stat/eco for temp control
t-stat OPENS at 140*F (Closes at 110*F)
eco OPENS at 180*F (Closes at 150*F)----triggers FAULT Light and 'Locks Out' ALL heating
Atwood XT Model GE6EXT uses one set of t-stat/eco PLUS a mixing vlave
t-stat OPENS at 160*F (Closes 130*F)
MIXING Valve set for 130*F output......HOT HOT water is mixed with cold to maintain steady output
Standard model.....BOTH T-stat & ECO would have to FAIL CLOSED
XT Model....BOTH T-stat & ECO would have to FAIL CLOSED OR the Mixing Valve Cold INLET is not mixing with the HOT HOT out
To Test 'heating cycle' (either model) with water heater ON and heating ----remove a RED wire from ECO terminal....all heating should stop and fault light should come on
