twogypsiesExplorerJul 20, 2013Hot water heaterWe have a suburban SW12DE hot water heater in our fifth wheel trailer. On gas it seems to work as it should. When we put it on electric the water does not get as hot. What could be the problem?
Old-BiscuitExplorer IIIJul 21, 2013Electric elements work or don't but because the electric element is submerged in the water crud can build up on it and lessen the heat transfer rate.How often do you drain/flush water heater?How often do you replace anode rod?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentWhy no hot water?Atwood water heater problemHot water heater question .....Smelly Water HeaterWater Heater Replacement Recommendations
