wa8yxm
Oct 18, 2017Explorer III
Second on the outlet check vlave,
If you have a single valve bypass system it is 100% you have such a valve
If you have a multi-valve.. You may still
Seen it before.. The RVer in that case was unable to get the valve off the heater so she (YES SHE!!) reached in with a pair of needle nose pliers and pulled everythign inside the valve out, Gutted it and turned into a pipe.
And she was Back in hot water again.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
