Old-Biscuit
Oct 19, 2014Explorer III
That year of Atwood uses separate t-stats for electric and propane.
Electric set are on backside of WH tank where electric element is located.
They are 110V AC t-stats (normal and an ECO/high temp)
110V AC power comes from circuit breaker to/thru electric on/off switch to & thru the set of t-stats to electric element.
Normal t-stat opening early, faulty element or poor connections.
IF model is GC10A-XX it uses a bolt on element
IF model is GC10AA-XX it uses a screw in element
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
