Mfar1234
Jan 25, 2014Explorer
Mfar1234 wrote:RoyB wrote:
This is a very simplified diagram of how the RV trailer water system is layed out. Might give a clue where to look.
If you have COLD WATER at at the sink then it must be at the INPUT to the water heater as well. Pehaps the winterizing bypass vales are not fully in the correct position.
This is a typical three value hot water tank bypass setup. Note the oblong values indicate which direction of water is affected. Might want to be sure the valves are completely turned.
HOT water worked great until yesterday eve
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
