powderman426
Jan 25, 2014Explorer
Mfar1234 wrote:powderman426 wrote:
I would start by opening the outside door and pulling the safety valve open just a bit to see if the water will flow from there and if its hot. Be very careful in doing this so you don't get burned.
Pulled valve at hot water heater - hot water does come out
Hey Powderman - I grew up in Mt. Vernon - where you at in Ohio?
I am from North Lima, which is about 10 miles south of Youngston.
After reading through all the posts, I would say its the check valve. I removed mine when it quit, and installed a single throw shut off valve. Those check valves are notorious for failing.:B
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
