Mfar1234
Jan 25, 2014Explorer
OK GUYS - HERE'S THE OUTCOME;
let the hot water side drip - left to run the dogs around 00930- Back around 1030 ... still a drip. Made lunch - talked w/ the neighbor ... by then its about Noon, 50 degrees!! Said !@#$ - took a nap woke up around 1400 to a drip. Decided to tap on the metal/brass fitting w/ a screw driver and then turned the bypass valve off and on a couple of times ---- WOW HOT WATER!!!
I think I'll install a light in this section...again, hot water heater and lines are in the large slide - this section also has a fairly large void where you can see through to the back of the shower and all water lines. light would cover; sink, shower and cold water in and out of hot water heater. I'm sure I rig a light in there - or my son can---I've a bit larger these days -lol! There had to of been a cool breeze coming in somewhere. We had high winds (slamming against that slide), sleet and around 15-19 degrees for about 8 hrs. Glad I found this out now before I take this baby in anything colder!!
NOW for the BIG POSITIVE --- decided to clean out the cabinet to the right side of the sink ---------------- found a 5th of JACK DANIELS ... I'm about to pour me one and toast all of you guys for the help .... THANKS GUYS I'm Back .... lol!!
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
