PenMan
Jan 26, 2014Explorer
Mfar1234 wrote:tenbear wrote:
I agree with Old-Biscuit. The check valve wasn't frozen. The hot water running thru it would have melted any ice long ago. The check valve could stick again anytime.
UNREAL --- You're right guys!
Check this out -- before shutting down for the night...I unhooked the water hose came back inside - hit the water pump and excellent HOT water came out of the sink great .... hit the bathroom sink and great HOT water ... then I turned on the shower (with the sink on) and BAM HOT water went away on all faucets. NO HOT water again!!!
Why once I switched over to the pump? and why did the problem start after the coldest night (19 degrees) I've ever spent in this unit?
Unreal --- ???
I tried to tell you.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
