opnspaces
Dec 17, 2019Navigator III
Is the switch a rocker switch or a smooth push button like the ones to check the tank levels? If it's a rocker switch then yes it should be replaceable. Typically a rocker switch can be pried out of the front of the mounting panel panel. You might also remove the entire panel from the wall so you can see the back of the switch. There should be some spring tabs on the sides of the switch that when compressed will allow you to push the switch out the front. From that point the switch should be replaceable.
