fischer
May 13, 2018Explorer
Fleetwood has a battery control center.
Everything goes to it.It is located under the engine hood and is labeled BCC.
1.inside is charging Relays for your batterys
2 You also have reset able breakers (red button)
3 when you push the button on the dash the click is jumping the coach and chassis battery together.
4 My chassis battery under the stairs lost its ground. it is bolted to chassis(check)
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
