MrWizard
May 14, 2018Moderator
you held the switch down, and the relay/solenoid burned out
that means it was NOT rated for continuous duty
you need to use a continuous duty relay for the battery charge relay
normally a 'intermittent' duty relay is only used for momentary contact
like for the emg jump start switch
either have not found the real battery connect relay (aka you are using the emg start)
or somebody miswired/replaced the original relay
the battery disconnect is almost always
a 'latching' relay, and they look different and are different
than the silver round cylinder charge relays and emg start relays
having a powered relay for the house battery relay would be a big drain on the battery, around 7-8 amps continuous
no RV mfg, does this
please post pictures of what you are replacing
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
