RLS7201
May 15, 2018Explorer II
If I read you correctly, the relay closes when you press the switch. So the wiring should be correct. That make me suspect the relay has lost the capacity to latch. For a temporary fix, you could move the battery wire to the other side of the relay. Check you private massages.
Richard
Richard
