dougrainer
May 01, 2023Nomad
enblethen wrote:
That means the switch or wiring is issue.
Remove the switch from the wall to gain access to terminals.
The both sets of end pins should have 12-volts DC. Switch should have opposite corners of switch jumper to reverse voltage polarity.
The center two pins should have 12-volts DC when switch is pushed.
see page five for basic wiring.manual
I didn't know Aloha still existed! Raised in Beaverton!
Be advised that the link to Intellitec is for 2020. The OP has a 2008. The difference is, in 2008, there was NO ignition blue wire. But the rest of the diagram is correct. 2 wires OFF the fuses. RED should have 12 volt power all the time. The GREEN should only have Power when the solenoid is closed(engaged). So, make sure the small red on bottom of fuse is 12 volts. IF the solenoid clicks, that points to a BAD solenoid. It also states 7.5 amp fuses. The OLDER system uses 5 amp fuses. The pic shows yellow wiring from Itasca. Some OEM's used their OWN wiring colors to the disconnect fuses and may not be yellow and green. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
