dougrainer
May 03, 2023Nomad
When you engage the inside disconnect button. DOES THE SOLENOID ITSELF CLICK? If so, you have a BAD solenoid. There is a copper disc inside the solenoid that is moved up and down to connect the 2 large posts and then moves down(away) to disconnect the two large posts. If it clicks the system is doing what it needs to do. The Solenoid is NOT doing what it needs to do, because it is defective. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
