dougrainer
Aug 02, 2017Nomad
1. The RVP manual packet should have a pull out sheet stating the Model and Serial number
2. If you pull the inside filter housing down you will see the Model and Serial number on the silver metal mount tray in front of the evaporator
3. The solar panel should have a quick connect for the 12 volt wires. AND most panels will just lay off to the side after removing the top shroud mount screws.
4. Why is it a concern? Inadequate cooling? If so, what is the length on the RV and how many slide rooms?
5. IF you have the 32 foot Silver Fox with a slide, a 15k is NOT going to cool your unit in hot weather. Units above 26 foot need 2 AC units.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
