path1
Aug 02, 2017Explorer
Good idea to verify...If like mine, take off inside cover and look up. Be careful undoing. Plastic
Also with their crowned roof gasket on top is sure mashed down compared to down hill side. Matter of fact, the tightening screws were so tight, almost torqued head thru bracket. Next good inspection I just put in flat washers and problem solved.
Other odds and ends to double check...dig thru the NW web site or send me PM and I'll pass on what all I check or did on mine. Great RV's but still put together by humans. I no longer belong to web site, but I think they want $10.00 a year.
I'm the guy you sent PM to about foam cushion store you like, about year ago, as memory jogger.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
