- HuntindogExplorerAll generators have limits. You have found yours.
It is operating normally.
If you want more power.... You need to pair another 2000 with it, or get a bigger one. - ktmrfsExplorer III
MrWizard wrote:
Honda 2000i
continuous is adv stated 1600w
13.3a at 120 = 1596
put the hair dryer on medium or low, might need a new hair dryer with more settings, or a lesser Max heat level
and also remember these are sea level ratings
if you like the mountains or high desert, the max output available from the Honda will be LESS than 1600
same goes for hot days 100+ temps will derate/lower the max output for overload
its NOT a 2000w generator
at its best it is 1600 VA aka Volt Amps, with a pure resistive load
and unless you plugged in the hair dryer or pop corn machine via extension cord, there are OTHER additional loads, like the converter
and even the fridge , IF you have it on automatic instead of manual LP setting
try your popcorn machine using an extension cord with the generator
exactly. and FWIW it will run at 1600VA at sea level continously. somewhere around 1800VA it will shut down after 30 minutes or less, 2000VA is good for a few seconds at best.
above sea level it may have trouble giving 1600VA continously. - road-runnerExplorer IIIIf you really want to test the output, you need to be able to measure it. A kill-a-watt meter is up to the job. The way I do it is to get close to the 1600 VA continuous rating, then add different size incandescent lamps to the load while monitoring the output. Forget the ratings of the load devices, they're all voltage dependent. That 1875 watt hair dryer rating is at 125 volts, which the eu2000i will not be producing with that big a load. As you increase the load past 1600 VA you'll find that the output power starts trending down because the voltage goes down. My observation is that once the voltage at the the eu2000i outlet goes under 115, you've reached maximum power output. You can pull more amps by increasing the load, but the voltage will drop such the the power output goes down. With an 1875 watt hair dryer as the only load, my eu2000i outputs 122.6 volts, 14.05 amps, 1720 watts.
- DamdifinoExplorer
time2roll wrote:
1875 is in the surge capacity good for 30 minutes.
I do hope your hair is dry by then.
Lol! I'm neither drying my hair nor popping corn. Just using those appliances to apply a load on the genny. - corvettekentExplorerI got tired of running outside to start the Honda generator in the morning so I installed a 2000 watt inverter. Now the wife can turn on the inverter and dry her hair.
- 1875 is in the surge capacity good for 30 minutes.
I do hope your hair is dry by then. - TomG2Explorer
Boon Docker wrote:
Actually at 1850 watts the generator is running at 115 percent of it's 1600 watt continuous capacity.
Surprised the little generator did not run backward with such a load.
Every portable generator I looked at has a surge and running watts rating whether they were made in Omaha or the Orient. - Boon_DockerExplorer IIIActually at 1850 watts the generator is running at 115 percent of it's 1600 watt continuous capacity.
- Chum_leeExplorerWhen it comes to specifications, . . . generally:
The large print and graphics are written/drawn by the sales, marketing, and advertising departments.
The small print is written by the engineers.
Chum lee - Chum_leeExplorerWhen it comes to specifications, . . . generally:
Chem lee
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
