RoyB
May 11, 2017Explorer III
The front panel of EU2000i 2KW Honda Generator says this...
Google Image
120V @ 13.3AMPS is 1595 Watts...
You also may have to consider that only 797.5 WATTS may only be available to use in each of the two 120VAC Receptacles... Some Generators do this with split windings inside the generator... Don't know this to be a fact with the Honda 2KW EU2000i generator...
Added NOTE: Just checked with FAQ's on AMAZON about how much power can be drawn from each 120VAC Receptacle...
"Question:
This gen is rated at 13.3a/16.7a max. is that 6.7a per outlet or can all 13.3 amps come through one outlet?
Answer:
It can come through a single outlet.
By Barb Plattes on March 5, 2016 "
Roy Ken
Google Image
"Question:
Answer:
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
