time2roll
Mar 16, 2017Nomad
If there is an existing outlet you do not need to pull wire.
Move the inverter close to the power distribution panel.
Use the main battery feed to get 12 volt power.
Use a small transfer switch to send power down the existing wire to the outlet.
I assume the inverter is 500 watts or less. With a larger inverter it is best to mount near the battery.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
