NinerBikes
Mar 16, 2017Explorer
Get a good amperage rated on off switch, wire it to the 12v side of the panel first, then wire in the inverter after the on off switch with it's 120v outlet.
How many watts is your inverter? You need to be able to turn the inverter off to reduce parasitic load, when not in use.
What is in your TT that you need 120V?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
