2oldman
Mar 16, 2017Explorer II
profdant139 wrote:Nobody hooks an inverter to a converter.. not directly anyway. Everybody hooks an inverter directly to the battery..if you want to run anything that takes more than a few amps.
2oldman, when you say "nobody hooks it up this way," do you mean no one hooks the inverter to the converter? Or do you mean no one hooks the inverter right to the battery?
Hooking the inverter to the converter would imply you have 120v power to the converter.. which means you don't need to use an inverter. I'm not sure what you mean by this.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
