time2roll
Mar 16, 2017Nomad
profdant139 wrote:The converter is just one component in the distribution panel.
This solution, if it works, avoids the issue of hooking the inverter to my converter.
You could connect the inverter power to the single circuit you need and not power up the entire panel. Yes if the converter happens to draw power off that same single circuit you could easily make adjustments so the converter component never gets powered up by the inverter.
If you prefer extension cords or surface wire molds from the inverter mounted in the front compartment that will work. Not my style.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
