SoundGuy
Mar 16, 2017Explorer
profdant139 wrote:
SoundGuy, that is very helpful -- thanks! Did I see fuses on the lines running to the battery?
Mine is a 1000 watt PSW inverter and because I typically don't pull any more than ~ 60 amps or so when powering a 750 watt toaster I used an 80 amp fuse in the positive cable where it connects to the trailer battery's positive terminal. My run is ~ 6' from the inverter to the battery so for this application I used 4 gauge cable ... other cable gauges can easily be determined using this Blue Sea DC Wire Gauge Chart.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
