westend
Mar 16, 2017Explorer
Connect your 800 W inverter directly to a circuit breaker/fuse and then to the batteries. Use 8ga or larger wire. The circuit breaker/fuse can be attached directly onto the battery terminal. Size the breaker/fuse to the size of the wire used.
Look at how I fused the battery lead (red) in this image:
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
