TurnThePage's avatar
TurnThePage
How do I block a furnace outlet at the manifold?
My furnace pumps the hot air from a manifold with three exits into hoses which then enter into another manifold that disappears under the floor. There is some blockage down there that is not easily accessible, so I intend to plug one of the three inlets on the bottom manifold and reroute an outlet from the feed side to a new vent.
My question is, how do I plug that inlet on the bottom manifold. I have quite a bit of aluminum tape laying around that I thought might work, but am wondering if the heat might melt the glue on the tape. do they make caps for those?
  • I'm not blocking any output from the furnace. I'm rerouting one output from the furnace and closing off one inlet to the receiving "PLENUM".
    Before I posted, I wondered what the correct terminology was and googled both terms. Obviously, I saw the wrong description for plenum.
    Good feedback! Thanks!
  • I agree with not blocking it, just add the new duct and try it out. The under floor duct may also keep tanks and such warm, and if it’s blocked right now there’s really no advantage.
  • Having had a 19T4, I remember (?) that the furnace had metal blanks that were knocked out to attach the outlet flanges. A piece of thin metal could be sized to fit over the opening and screwed or riveted on to block one outlet. ??
    As to blocking and overheating, the furnace has a hi-temp cutoff switch that would prevent that from happening. And if you open up another outlet, the air flow should be the same or nearly. If the floor duct is already restricting the flow, obviously the system is still working!!! Had one trailer that "operated" on the cutoff switch when heater running!! Ran that way for years before getting another trailer!!
  • It is called a plenum, not a manifold!
    I would not plug anything off because it cause the furnace to over heat.
    Odds are the duct has collapsed. Yes, it can be difficult to gain access.
    Make and model of furnace would or may help. The installation manual may show how toremove furnace to get to the duct through that access.
  • If you are just removing one of the other "furnace vent outlet covers", use the new one to cover the old one (at least on the furnaces I have worked on).
    Worse case is buy a small sheet of aluminum from any box store, drill holes at the corners and screw it over the old hole. I would not trust any glued product in that high heat environment.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
