fcooper
Jul 13, 2014Explorer II
I looked at all of the available info I could find on the Bryant RV site, and did some other google searches with no joy. I could find a parts list with an illustration but not enough detail to help with taking it apart.
Today I got the door trim disassembled via brute force. Norcold glued it all together including a foam board core that goes into the top and bottom trim strip. The bottom trim strip has a socket (plastic) with one screw that holds the hinge arm in place. Of course this trim strip socket and screw support has been broken for some time.
If your Norcold Refrigerator has a wobbly bottom hinge, I'll bet that it is broken in the same area as it does not look very strong.
I'm trying to fabricating a thin steel bracket that I can use to reinforce the hinge support. I'll post info later if it works.
Fred
Fred
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
