- 96Bounder30EExplorer IIMoved from DIY
- CincyGusExplorer IIBuy a foldable table to put the grill on and it will give you much more room and flexibility.
I use a 6' long, 3' wide plastic banquet table that folds in half (3'x3'). I open it up and put my weber Q100 and a two burner coleman propane stove and still have room to put a serving tray and my tongs, spoon for stirring whatever is on the stove. Very nice "outdoor kitchen" which we use all the time instead of the inside kitchen unless it's raining hard enough I can't have the awning open. - Photog101ExplorerCara:
I put a propane grill on the side of a motorhome, thinking that it would be great for tailgating parties. Charcoal would have been worse. Way to much heat against the side of the coach and the smoke and grease always made a mess. The inability to move it also proved to be a problem when the wind shifted.
I finally fabricated a bench to utilize the existing brackets and extended the grill away from the coach. I was still was not impressed with my modification.
Lots of better options with collapsible grilles these days. - mister_dExplorerWe loved using the grill on our previous HTT. We used it almost every night and never had a problem. Our wall was fine and the awning never had grey/black smoke damage. We now bring our full sized Weber which is way better but a bigger PITA.
If you do screw the rail into the wall, you'll definitely want to hit at least one stud. On our current TT, I added a rail so we can hang a shelf (made of countertop). I got the stud locations from the TT manufacturer. Another way to find them is to wake up early in the morning when the dew is on the unit. I'm not sure if a stud finder will work. Be sure to fill your holes will caulk before screws. - DtaylorExplorerHere is a discussion that has been going on about grills in the General RV topics: http://forums.trailerlife.com/Index.cfm/fuseaction/thread/tid/26947107.cfm
Might give you a little piece of mind about heat and grease concerns - HoustedExplorer IIIMy daughter gave us an RV Que and I use one of these with a hose to the rig...Coleman Stove Stand
Quite stable and works great.
Housted - CaramiaExplorerI have an outback that has a little "kitchen" on the side. It's really just a double burner and a small sink. Thought that it would be nice for the grill to be mounted next to this, but I guess you all are right. probably more trouble than it is worth. I will just get a table to set it up on instead. Thanks for all your input.
Cara - BumpyroadExplorer
ScottG wrote:
I've thought about it and came to the same conclusions.
Plus, the heat gets too close to the RV, I don't wan't more holes and eventually the cheap grade of BBQ will be burned out and discarded and then you have this bracket hanging on the trailer that you don't need.
good reasoning, X2
bumpy - lpxguyExplorerTake a look at the setup the Crusader 335BHS has...mounting bracket is attached to the rear bumper and swings around towards the front for use...plenty far away from the coach....can't wait to use mine.
- TachdriverExplorerjust checked mine, it uses screws but it hits some sort of support.
As far as usage you can still use it without it on the rail.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
