ScottG
May 15, 2013Nomad
downtheroad wrote:
Just another thought...
I wouldn't do it. The fewer holes you have in your rig the fewer places you have for leaks.
I really like the versatility of a free standing grill. I can move it out of the wind, down to the lake or beach, put it on the picnic table, where ever.
If you do drill and mount...it must be done very carefully and very SECURELY so that the heavy grill does not pull/rip away from the wall and damage siding.
Also there are heat concerns from a hot grill and siding..
We had a previous rig with a side mounted grill. I just didn't like it and went with a small Weber Q.
I've thought about it and came to the same conclusions.
Plus, the heat gets too close to the RV, I don't wan't more holes and eventually the cheap grade of BBQ will be burned out and discarded and then you have this bracket hanging on the trailer that you don't need.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
