- 1971duster340ExplorerIf it's leaking where the hose connects the fitting, then yes, you can trim some hose. Loosen the locking ring, unscrew the connector and trim.
If it's leaking at the fitting inself, time to replace it. - past-MIdirectorExplorerThere is a gasket replacement kit available,
- BobboExplorer IIIWhere the hose attaches to the fitting, the fitting shows how to turn to lock/unlock. Turn it to unlock and the hose can be pulled off.
The time to discover this "feature" is NOT when you are dumping. Don't ask.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
