bounder39zman
Jul 30, 2018Explorer II
At our shop, often use motorcycle jack, or floor jack. Mostly use fork lift, although I realize that it is a luxury to have concrete floor and a FLT.Also sawed up some 2x8 treated boards and made some drive on ramps to get that little extra clearance often needed to slide genset out the side. From pics, looks like a little bit of air cleaner clearance issue.
Hope those parts fix your problem. ONAN used that rotary pump with a electric shut off valve on early Marquis sets; later sets just used a pulse/piston type pump. we normally will replace rotary pump/shut off valve with low pressure pump, due to excessive cost of rotary pump and valve
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
