kccwoodworks
Feb 09, 2015Explorer
How Level is Level
Being new to RVing I've heard lots of talk about leveling your RV. Mainly due the peculiarities of RV refrigerators. How far off level before damage to the fridge? 1", 2", 3"???
Bumpyroad wrote:
that is why I leveled my MH with the level on the floor of the freezer compartment, then stuck a bullseye level on the console mushing it into a glob of silicone sealer to show level. then I could just level based on that and knew the refrigerator would be fine.
bumpy
Bumpyroad wrote:
To put it more simply, if you refrigerator is located along the side wall like mine is then:
multiply your RV width across the tires in inches by 0.1045
and multiply your wheelbase in inches by 0.0523
Calculating the inches out of level allowed for the refrigerator requires that you know the wheelbase of your MH (the distance between the front and rear wheels) and the distance side to side between the center of the tires. After that, it's simple trigonometry.
In my MH the refrigerator is located along the side wall on the passenger side. Front to back on the fridge is therefore side to side on the MH, so I am allowed to be off level in this direction by 6 degrees. I measured 73 inches across the tires, so multiplying 73 by the sine of 6 degrees (0.1045) gave me an allowable out of level of 7.6 inches. The fridge is allowed to be off level by 3 degrees side to side, which is front to back on the MH. My E450 chassis has a wheelbase of 158 inches, so multiplying 158 by the sine of 3 degrees (0.0523) gives me an allowable out of level of 8.3 inches.
turbojimmy wrote:
My issue is that it depends on where I set the level. Galley counter is totally different than the living room table, which is different from the dash in the cab which is different from the floor of the box where the fridge is mounted. I use the dash in the cab because when it shows level, the whole rig feels level. The cooling unit in the fridge is new so I'm hoping it's not too sensitive. Seems to work well irrespective of level (so long as it's not way out).
