pianotuna's avatar
pianotuna
Nomad III
May 19, 2016
how long does the fridge stay cool?
Hi,
I was forced to park in a manner where I thought it prudent to turn the fridge off.
I've often seen folks claim the fridge is cool after many hours. This appears to be apocryphal.
The fridge:
Dometic Royale Tri-Fuel Fridge (6 cu. ft.)
The conditions:
I parked with the fridge on the north side so it was not in direct sunlight. Ambient temperature was 22 C (71.6 f). There was mixed cloud, and it was 1 p.m.
Interior of the RV was 22 c (71.6 f)
Interior of the fridge was 2.7 c (37 f), measured on the top shelf of the door.
After 2 hours the interior of the fridge had risen to 6.4 c (43.5 f)
The drain tube is properly set up with a dip in it to prevent air infiltration.
As I knew I would have power later, when I restarted the fridge I did it on 120 volts via the inverter. Input from alternator and solar to the fridge were about 25 amps. I drove for about 2 hours and the batteries were quite happy to start recharging at 24 amps once I had shore power. While the fridge was playing catch up duty cycle appear to be 100%.
The fridge was not opened and the interior was still at 4.5 c (40.1 f) after the two hours of run time. It is equipped with a dual interior fan, and dual "chimney" fans that sucks air over the exterior coils. The unit has the ARP control installed. (I love having that btw--no more driving in endless circles in parking lots to get perfectly level!)
My conclusion is that the fridge can be shut down for only one hour from a safe food storage point of view.
