ktmrfs
Jun 11, 2015Explorer III
Carvin Marvin wrote:
Just curious how many run hours on a gallon of gas. Currently at 7000' using econo mode to run the battery charger can I expect? It is a 3 stage charger.
somewhere between the min and max runtime that honda spec's.
If your charging a big bank with 60A, about the most you can reliably get out of the honda for VA, you'll be running near 1600VA, the honda max continous power. If your running a lower amp charger it will run longer.
eco mode will adjust the output power to whatever the charger needs.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
