S_Davis
Apr 27, 2020Explorer
How many Ah
I need a battery bank to power a mini fridge 1.3 amps @ 120v for 48 hours and a electric blanket 200 watts @120v 8 hours as well as computer and cell phone charging, how many Ah will I need?
wa8yxm wrote:
That's three pair of GC-2 ...
vermilye wrote:
Just a quick note - be sure to use a pure sine wave inverter. Most electric blanket controls will not work on a MSW inverter.
DrewE wrote:
... so I'd say a minimum of 500 Ah if you aren't talking about lithium batteries. Six GC2 golf cart batteries would be one reasonable setup (with a bit of margin).
S Davis wrote:
Ok so the batteries will be Lifeline AGMs probably the GPL-31XT, I was thinking of starting with two.
Harvey51 wrote:
If you mean energy from a 12 volt battery, conversions from 120 v to 12 volts will mean ten times as much current.
It will require at least ten times as much current from a 12 volt battery to convert to 120 volts
fridge 1.3 amps @ 120v for 48 hours AH = 1.3 x 10 x 48 = 624
200 watts at 12 volts is 200/12 = 16.67 Amps. AH = 16.67x 8 = 133 AH
