rk911
Jul 01, 2017Explorer
Rynofire wrote:
Min 2, most 5. I am recharging with 100 watt solar panel though.
watts is watts and amps is amps. if the amplifier is powered by 12-volts then your max amps would be 600/12 or 50-amps. yes, you won't or shouldn't be running those speakers at full wattage. let's say you run them at 6-watts or 1% of the max volume (to illustrate the point) the formula would be 6/12 or .5-amps. if both speakers are drawing 6-watts then the formula is 12/12 or 1-amp. get it? if you ran your amplifier at a 1-amp draw continuously for 24-hrs the total draw would be 24-ah or amp-hours.
