How many batteries are needed to insure that a Progressive Dynamics PD4655V (55 amp using 4g wires) will go into boost mode when the batteries are at 50% SOC?
Not quite. Yes for sure if you force boost with the CW. Not so sure if you let it act on its own. Perhaps you could run a test on that as a follow-up?
With test result please also add how long those #4 wires are and if pos and neg both all wire or if neg is part via frame, as can affect what the converter "sees"
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
