DrewE
Apr 02, 2018Explorer III
Mont G&J wrote:
The answer to the OP's question.
How much gas does a standing pilot use?
Again, this goes back to the design of the burner. A thermocouple system uses about 700 btu's per hour while a thermopile system about 1500 btu's. I find it easier to understand volume in gallons; a gallon of LP gas contains roughly 91,500 btu's. A thermopile assisted burner therefore uses one gallon of gas in 61 hours, or nearly 12 gallons a month. A thermocouple system would be roughly half that amount.
Your oven pilot uses the thermocouple design.
My RV oven pilot uses neither design, actually. It's a standard two-stage sort of pilot. When no heat is being called for, it just runs with a teeny tiny flame. When heat is called for, the pilot is enlarged (more gas is fed to it) and it grows to envelope and heat the bulb of a thermostatic safety valve.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
