filrupmark's avatar
filrupmark
How to add 2nd. A/C
I have a 30 amp fifth wheel. I would like to add a 2nd A/C in the bedroom. A RV dealer told me they could add a 20 amp drop leg. That would be the 2nd ac wired directly to a seperate receptacle mounted on the side of the trailer. I would have to plug in my 30 amp cord like normal and then if I wanted to run my 2nd ac I would have to plug in a extension cord to the seperate receptacle and then plug the cord into the 20amp outlet next to the 30 amp on the park power . Has anyone ever heard of this. That would mean that the parks power would have to be wired for 50 amps total.??????????????????
  • REWahoo wrote:
    One suggestion: when wiring the 20 amp service, include a separate wall outlet in the bedroom. This will allow you to run an electric heater off that circuit in cool weather.
    good idea
    bumpy
  • Thanks for your post. I think we will go ahead with the drop leg system. I was originally concearned that the 30/20 amp pedestals might not handle the two A/Cs. I figured what good are two A/Cs if you cant run them.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
