pianotuna
Apr 28, 2021Nomad III
BFL13 wrote:
On solar,
1. How do you meet the spec that says do Bulk at 20% charging rate?
That would mean a lot of watts on the roof.
2. How do you maintain that charging rate while the sun goes up and then down?
3. How do you know you are down to that 0.5a/100AH? The solar controller amps go to loads first, so without a battery monitor or some other ammeter at the battery, you don't know what the amps to the battery are.
1. not necessary for low slow charging. The telecom cells reacted well to just 17 amps of charging--with temperature compensated voltage. Battery bank size is 556 amp-hours.
2. the charger picks up from where it left off.
3. my blue sky 3024di blue sky charge controller displays voltage and current alternately.
