Gjac
Jul 05, 2015Explorer III
I don't know what model refer you have but I changed mine in a Norcold 682 with out removing the refer. If you look at the manual it tells you how many ohms it should be between leads to see if the element is bad. If it is I posted a detailed how to remove the element on here. If you search under gjac over 1 year you can read it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
