MrWizard
Oct 03, 2017Moderator
Well maybe
You can buy DC to DC power converter/regulator
What is the power rating of the TV, 50w? 100w
Check out Drock DC power on eBay or Amazon you will want one that is 'buck' aka reduces voltage
Or a Buck boost, one that does either reducing or increasing (you will be using Buck mode)
A boost only will not work for your application
Shore power converter charger voltage is always higher than 12v a k a 13 to 14+
So a boost only won't do the job
You need to knock the 13.6? Down to clean 12v,
