maillemaker
Oct 03, 2017Explorer
Unless you are disconnecting the batteries when you are on shore power, you are running off the batteries all the time you are on 12V. On shore power, your convertor comes on to charge the battery. It is possible your convertor is so noisy it causes issues with your electronics, but a battery is a pretty good filter to remove the noise so it would have to be fairly significant.
Yes, everything is 12V, shore power or not, but the noise is present when on shore power. It's not that the converter is bad, it's just 30 years old and back then they didn't have sensitive electronic devices running on the internal 12V circuitry in the RV.
The converter is a B&W Model 6332. I have no idea what to replace it with.
Steve
