myredracer
Aug 12, 2014Explorer II
96Bounder30E wrote:
Here is what I did on the back of my toilet.......
Thanks! That's essentially what I want to do. Where did you get that hose with pre-installed fittings or is that just what was there originally? It looks like you installed a new compression fitting to the PEX? I guess can do the same with metal braided residential line.
I was thinking I could just cut the existing hose and slip in a new shutoff valve and crimp it on. On further inspection, I see that a PEX crimp ring won't fit the hose diameter. Attaching the valve directly to the toilet seems like the easiest solution.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
