jesseannie's avatar
jesseannie
How to Direct Wire Inverter
I have a 400 watt continuous 800 watt peak Cobra inverter. It has 2' long clamp on style connectors for attaching directly to the battery.
I would like to direct wire the unit and install it inside the trailer about 12' from the pair of TT batteries or alternately wired to the electrical panel that is located under the bed. (easy access)
I will only be using the invertor to charge my phone, camera and to power two laptops. I am not going to try to operate any appliances.
In my last trailer I had a unit that I was able to wire to the main electrical panel in the trailer. This unit did not come with any option to do that.
Any help would be appreciated.
PS Yes I did do a search and so many of the questions had to do with larger units and solar power.
jesse
  • I wired my 300w inverter behind the main breaker/fuse panel. Connected the 12v to the existing 12v feed to the battery. Used two transfer switches to connect to the two 120v branch circuits that feed the outlets. I would use the small Xantrex Prowatt transfer switch if installing today.
    If you are just charging small items or running a tv/dvd you will be pulling about 1 to 8 amps maybe 20 max so the wire is not a huge deal. Virtually no surge issues at this level.
  • OP again. I think I am getting the picture. Put the inverter as close to the 12 volt power as possible and run 120v further if needed.
    So my next question is: the TT electrical panel is under the bed at the opposite end as the batteries is there a way to wire it in there.
    At that location is there 12 volt power from the battery that I could tap into. The batteries are on the tongue of the trailer outside so that is pretty inconvenient.
    The inverter is self contained it has an off/on rocker switch and two 120v plug-ins.
    jesse
  • Hi,
    12 feet is a long run for DC power. I'd suggest keeping the unit within 2 or 3 feet of the battery bank.
    The 120 AC side doesn't suffer from voltage drop nearly as much.
  • You can cut off the ends of the wires going into the inverter and install a plug. Then run some #10 wire from the battery to a 30 amp fuse, then to a electrical plug. THen you can plug in the inverter anytime you want to. Check here for a sample 30 amp plug, I would suggest a locking type, so nobody ever plugs it into a 120 or 240 amp plug in a home. http://www.homedepot.com/s/30%2520amp%2520plug?NCNI-5
    Then you can plug in the TV or charger when you want to. For that, I would suggest a power strip, and then plug in each thing to that. You can use a 15' extension cord to run the high voltage much less money than running the #10 wire to separate the inverter from the battery. In other words, it is better to use shorter 12 volt wires that is very large diameter (due to having 10 times higher amperage at 1/10 the voltage) and a longer 120 volt extension cord then to run longer 12 volt wires then plug in the charger directly to the inverter located near say the coffee table.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
